[6N2] Tempomat w 1,4TDI za grosze
christensen
Post autor: christensen »
Could somebody tell me which bits have to change when an action is happening:
- Power the CC
- turn ON the CC
- Push SET button
- Push REM button
- depress Brake pedal
- depress clutch
it the CC isn't Powered/ON in the measurement block will be any changes when i depress the clutch?
Marianoo
Post autor: Marianoo »
[size=12px][/size]
christensen
I've checked again, the wiring is ok.I had take a look in measurement block and i found some issues.
When the CC is ON there is no change in the bits.
When i press the clutch there is no change again :(
The only changes are for brake, Set and Resume buttons.
Here are the print screens:
All OFF:
Brake ON:
Set ON:
Resume ON:
Marianoo
Hmm ... do you have...
pin38 - clutch pedal released >12volt
pin38 - clutch pedal depressed 0volt
Do you have ecu control 030906032DT?? It is not working with cc :/
[size=12px][/size]
christensen
The clutch pedal switch is ok, 12V => ON and 0V => OFF.
When i switch ON the CC, ECU does know that is ON(there is no changes on measurement block). I've activated the CC on ECU and it show that is activated! but the CC doesn't work.
I've checked the wiring and all is good!
Here is my ECU part no. : 030 906 032 AP
Marianoo
can you show me a wiring diagram?
Switch on/off CC is good??
Maybe you should do change in the software and new flashing your control unit?
Where do you live? :)
[size=12px][/size]
christensen
Here is the wiring:
The switch is good, i've modify the turn-light stalk to CC one(from a golf3)
Here is a picture:
I could re-flash, i have the tools (Galletto 1260 ... MPPS V12 and a few mcu/eeprom/flash programmers) but i don't have the firmware for the CC of this ECU type :(
Do you have?
I'm from Romania ;)
Marianoo
I don't have firmvare :( But i look now for your screen
http://postimg.org/image/z1g2nrixv/
and ME7.5.10 3245 - this is CC not activated
ME7.5.10 G... this is CC activatet in ECU.
Only modification firmvare maybe help you in problem
[size=12px][/size]
christensen
It is activated, the screenshot is before activation!
Maybe it is a tuner here on this forum and can help me.
I've worked a lot for this modification and i don't wan to leave like that.
bicker83
Post autor: bicker83 »
Panowie czy jakby kupic manetke z tempomatem z golfa 3 to da sie to przelozyc do 6N2? Sam ksztalt manetki jest taki sam tylko ten ring ruchomy ma w sobie wlacznik awaryjnych dlatego pytam czy da sie swapa do polowki zrobic?
http://allegro.pl/manetka-tempomatu-vw- ... 44816.html
Marianoo
Z manetki golfa wyciagnac 'wajhe' i wsadzic ja w manetke polo i bedzie smigac. Ale 250zl to sporo ceni. Ja mam manetke tempomatu do 6n2 z wiazka, ale manetka stracila napisy przy czyszczeniu:( Aby na suwaku kreska zostala:( To za taki komplet z wysylka licze 160zl:)
[size=12px][/size]
christensen
[quote=""bicker83""]Panowie czy jakby kupic manetke z tempomatem z golfa 3 to da sie to przelozyc do 6N2? Sam ksztalt manetki jest taki sam tylko ten ring ruchomy ma w sobie wlacznik awaryjnych dlatego pytam czy da sie swapa do polowki zrobic?
http://allegro.pl/manetka-tempomatu-vw- ... 44816.html[/quote]
You can use the stalk from golf, passat 3, for example mine is from a golf 3 and i just remove the lever with the wiring of CC and attached to my original 6N2 switch(the base of the switch where are the contact blades)
from vw T4 is fitting 1:1.
ruski28
Post autor: ruski28 »
Witam, odkopuje temat tempomatu w 6n2 1,4 AUD. Udało się komuś zrobić tempomat w tym modelu? Jeśli tak to mógłbym prosić o jakies instrukcje dla "żółtodzioba" w tym temacie??
mario00760
Post autor: mario00760 »
Witam.
Czy ktoś ma foto story do zrobienia tempomatu na zwykły włącznik w tdi 6n2? Na 1 stronie niby jest opis ale fotki poznikały.
Jest VW POLO 6N2 1.4 TDI
Było VW POLO 6N 1.9 D
DEFENCE
Post autor: DEFENCE »
Witam :help: :help: :help: :help:
Jadę sobie autostradą i tempomat nagle odpuścił prędkość i przestał działać ? czujniki sprzegła,stopu,gazu działaja sprawdzałem Vag-iem. Spróbowałem jeszcze raz zaadaptować kodem i nadal nic
Ktoś zna przyczynę ????
